I have a dvd which I would like to backup, however I need to shrink it down but I would like to leave the video untouched. What programs would be best to remove extras and also retain the menus (the menu links to the removed extras should be disabled)?
Also, I might want to transcode some extras instead of totally removing
any suggestions?
I was reading a tutorial which involved both dvdshrink and dvdremake, however dvdremake is a difficult program to find.
You may want to try Titlesetblanker or VOBblanker to remove unwanted extras before using DVDShrink.
My self I use clonedvd2 to remove extras, but keep menus. And then I re-encode using dvd rebuilder, using CCE SP.
How do you add menu links in TMPGEnc Authoring Works 4
By philled in forum Authoring (DVD)Replies: 1Last Post: 27th Nov 2009, 10:47 -
Add subtitle, keep menu/extras
By canaQ in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 06:36 -
Delayed Links, Motion Menu and DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 14Last Post: 30th Apr 2008, 02:33 -
Adobe Encore CS3 - quick way to create 100 menu links?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 4th Apr 2008, 23:17 -
keeping the menus, removing the extras
By Belfour in forum Authoring (DVD)Replies: 5Last Post: 23rd Jul 2007, 10:27
