I have several xvid files that are about 50 in length and at 23.97 fps. I am having trouble converting them to dvd. I am wanting to put at least 3 of them on a dvd(with quality loss--i know). I first export the clips audio as an uncompressed wav, and then i convert the video using VDub. I then take both new clips in to TMPGEnc and convert them. But my audio is still out of sync.
The reason i am posting, is because i am very confused by some other posts, and i would like a step-by-step process.
Here is everything I know about the clips taken from AVIcodec:
File : 349 MB (349 MB), duration: 0:50:22, type: AVI, 1 audio stream(s), quality: 36 %
Video : 312 MB, 866 Kbps, 23.976 fps, 512*384 (4:3), DIV3 = DivX v3MPEG-4 (Low-Motion), Supported
Audio : 37 MB, 104 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
Some of the other programs, that i see a lot of people using, really confuse me and I never know what settings are best.
So any help for an extreme Newbie would be appreciated.
Thanks a bunch,
videoman77
Results 1 to 9 of 9
1. The AVI is NTSC so do you also want to create a NTSC DVD?Originally Posted by videoman77
2. Were the audio and video in sync before passing the AVI through VDub? -
Thanks for the quick reply.
1. Yes I do want to make an NTSC DVD.
2. Yes the video and audio are in sync prior to Virtual Dubb -
Do you mean conerting to standard avi first and then re encode?
What programs would you suggest using for this process? -
Do you mean uncompressed? Where do i tell it to encode avi and not mpeg?
Never mind I see it...I'll give it a try and let you know. -
Do i need to export it as is, or do i need to export it with the wave file that i already extracted?
why are you processing the video through vdub before running them through tmpgenc? That's an extra step you don't need.
when you run them through tmpgenc, are you using 3:2 pulldown?
Issues Converting from 25 fps to 29.97 fps
By Klagar in forum Video ConversionReplies: 7Last Post: 13th Jul 2011, 11:30 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 06:56 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
trying to convert an Xvid avi to mp4 w/ SUPER. audio is out of sync!
By cduval04 in forum Video ConversionReplies: 3Last Post: 10th Oct 2007, 18:45
