I am trying to convert an avi to mpeg to burn a VCD to play on my DVD/Video CD player. However, all the avi files I've been downloading are coming in at rates not compatible with Nero buring (not PAL [25.00] and not NTSC [29.97]); most of my avi files i've been downloading have been either 20.00 or 15.00 (14.97) fps. Is there anyway to convert these abnormal fps to either PAL or NTSC without desychronizing the sound and picture??? A friend of mine said this was the place to get the answers; also, is there a way to determine fps on a file before i get it from winMX or morpheus? Thanks![]()
If it's 20 or 15 fps, it should convert fairly well to 30 fps without losing much quality. When you encode, do a framerate conversion.
TMPGEnc will convert the framerate. If you use an encoder, that can not do that, you can use Avisynth to frameserve.
The command
ChangeFPS(fps)
will change the framerate by deleting or duplicating frames.
I assume that TMPG work in the same way.
That's why the final MPEG will hardly play as smooth as the original.
Idx/sub frame rate
By -Sandro- in forum SubtitleReplies: 7Last Post: 30th May 2009, 15:32 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Frame rate conversion
By Alexstarfire in forum Video ConversionReplies: 35Last Post: 22nd Aug 2007, 14:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15 -
nero frame rate
By bong1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 30th Jul 2007, 16:50
