I cannot get the subtitles to work out with my converted movie. I have tried to search for a step-by-step guide on how to do this, but I could not find any info on it. The documentation is not very clear for me on the site, so I figured I would ask here.
1, I used OSEx to create a VOB file.
2, I added it to ffmpegX, then under the "Filters" button I extracted the subtitles to an .idx format. I tried .srt as well, I just did not have the patience to retype the whole movie. It kept asking every single word...anyhow.
3, Then I used XviD format the normal way I do (set movie properties, sound, quality, output). I also checked the subtitles button under "Filters" also "Loaded" the .sub file, selected the Burn option and started the conversion.
4, As a result I have the following files:
movie.idx
movie.sub
outputname.avi
outputname.avi.idx
outputname.avi.sub
original.vob
where movie does actually show up as movie, the "outputname" and "original" of course refer to my specific movie name.
5, I tried to play the movie using VLC, but no luck. The subtitles do not show up. Of course I do not really know how to tell VLC to play the subtitles, but I tried to open the .idx and .sub files with it, but it is a no go.
The .avi file plays just fine. The video and audio are all there. I thought that the subtitles were supposed to be burned into the video. Isn't that the case? Is that actually possible?
If not how can I play the video showing the subtitles as well using VLC? Did I do something wrong? Thank you,
d
How do I create a slideshow of photos and short movies?
By wreckage in forum Newbie / General discussionsReplies: 8Last Post: 21st Oct 2011, 04:44 -
Trying to create a process for creating home movies reliably and need help
By Arphahat in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2009, 12:19 -
How to create album art for Movies?
By siratfus in forum Newbie / General discussionsReplies: 2Last Post: 1st Aug 2008, 06:23 -
Number of Different Programs used to create your DVD movies?
By Jedi5 in forum Newbie / General discussionsReplies: 18Last Post: 7th May 2008, 19:36 -
Looking for a better way to create subtitles from hard-coded movies
By moviebuff2 in forum SubtitleReplies: 4Last Post: 16th Jan 2008, 07:12
