  1. I need to encode a compliant VCD, but the traditional template that comes with tmpgenc, is very vulnerable to the blocks.
    Is there any tip to reduce blockiness ?.
    Any good configuration for "quantize matrix" or "GOP structure" to reduce blocks ?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    You could try the kvcd templates found in the tools section to the left <----. Those aren't 100% vcd standard but will improve quality. It might be worth a look.
    Kevin
  3. i've already tried those templates.
    but i need a setup for CBR-1150.
    It's hard to reduce the squares when CBR.
