i notice that bulkpaq dont support the 107 and says nothing about the 108, just wondering is there a firmware upgrade to allow me to burn at 8x onto bulkpaq media with my 108, or am i just better off getting a ritek media next time
i have downloaded the official 108 1.10 firmware upgrade
Only one way to find out and thats to try one. Think its more of a case of the burner not supporting the media.
From SVP site
{DV 3130} Bulkpaq (8x) DVD-R Discs in Spindle Tubs of 25
Bulkpaq have proved with this disc they have access to the very latest cutting edge disc technology. In fact, in some ways this technology is too new because this disc is not included in the firmware compatibility list of some DVDR writers yet!
This new disc is recognised as 8x in the following drives:
NEC 3500
NEC 2510
NEC 2500 (Firmware 1.07)
In the Pioneer 107 it is currently recognised at 4x (This should increase to 8x in a future Pioneer firmware release)
Bulkpaq have negotiated a special price for this disc due to its current compatibility issues. The result is that if you own an NEC 2510 writer or and NEC 2500 running firmware 1.07, these are a bargain 8x disc!
Amazing value at under 24p a disc for an 8x DVD-R !!Not bothered by small problems...
Spend a night alone with a mosquito -
Originally Posted by dun4cheap
where can i get a hack from that supports the 108 -
Here is the link to the official firmware page.
108 hack
http://forum.rpc1.org/viewtopic.php?p=129219#129219
Problems with Alba 108 DVD player
By Normie in forum DVD RippingReplies: 1Last Post: 13th May 2010, 12:44 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Burn large MKV file onto several DVD-R disks
By fazza8 in forum Authoring (Blu-ray)Replies: 3Last Post: 11th Jan 2009, 07:28 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
What burner should i use to burn double layer disks
By Trident5 in forum DVD & Blu-ray WritersReplies: 8Last Post: 25th Sep 2007, 06:51
