Should I use something like BeSweet as an audio encoder or is the program itself fine as an encoder?
I tried to use a version of BeSweet that I had and it told me invalid AC-3 encoder. Any recommendations on what to do about the audio encoder?
BeSweet is fine for general encoding/convrsions, but for AC3, I'd suggest you use AC3 Machine. It uses the same engine, but seems to be much less flakey. Especially when changing 5.1 AC3 audio (example 5.1 PAL to 5.1 NTSC). There are a variety of freeware/open source AC3 encoding options out there. Check the CODECS section in TOOLS to your left.
Impossible to see the future is. The Dark Side clouds everything...
tmpgenc 4 audio no AAC encoder?
By sychern in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 22:06 -
downloaded video file, has buzzing audio when put into encoder
By efiste2 in forum Video ConversionReplies: 3Last Post: 22nd Jun 2009, 13:55 -
fails to set default audio device using Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 01:12 -
HC Encoder vs. audio
By awesomer in forum Video ConversionReplies: 7Last Post: 27th Jul 2008, 22:10 -
Windows Media Encoder broadcasts audio from one PC but not the other
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2008, 13:48
