Okay folks, I've searched the forums long and hard but can't figure this one out. I realize, in order for DVD video to display correctly on a television, you must leave the video interlaced (capture, edit, encode, burn interlaced). But say, for instance, that after you capture the video, you want to apply some editing (using VirtualDub, for example). From what I understand, interlaced video won't display correctly on your computer screen. So how are you supposed to determine whether or not your video will display correctly on your television?
I guess my question is this: Is there a VirtualDub filter, or a different piece of software, that will allow you to de-interlace interlaced video then re-interlace that same video after you apply editing, filters, etc.
Is it possible to interlace de-interlaced video?
Most good editing programs take care of this for you. This includes making sure what you see if clear, and that you cut on a frame (2 fields) basis, not between fields. I use Vegas (and have used Premiere and Video Studio Pro) and have never had an issue with this.
I think you are making more of it than you need to. Do you have a specific instance in mind where this is a problem for you ?Read my blog here.
No, there is no specific instance where this is a problem for me. I just want to make sure the video I "fix-up" will display correctly on my television. And since I'm going the cheap way (using almost all freeware programs), this is kinda hard to do. Thanks!!
I'm actually capturing video from a VCR. All analog baby. I'm sure I'll figure it out. It's just gonna take a little more tinkering. Thanks so much for your help!
Progressive DVDs work fine on TV's. And on the PC the Software DVD-player de-interlace the video for you... However if you play it in Media Player it will not de-interlace..
/Anders//Anders
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 22:09 -
Interlaced frames and audio editing...
By takearushfan in forum Newbie / General discussionsReplies: 2Last Post: 30th May 2011, 11:39 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48
