I’ve recorded some TV programmes using a TV card in DVD MPEG-2 format. Each programme (1.5h – 2h long) is a file 4.5GB-5GB in size. I would like to burn these on to a DVD-R. There are two possibilities here I think:
1. Burn them to DVD-R as a DVD movie, or
2. Compress them and store them as such on a DVD-R.
The 1st method will likely be difficult as the files are larger than the DVD capacity as they stand. Should I create a DVD on my hard drive with the relevant files (3 of them) and then use DVD Shrink to try and shrink them to fit on a DVD-R? Will this work?
Would method 2 rely on me converting them to DivX and then burning the resultant MPEGs to a DVD-R? If this works will I be able at a later stage to copy the MPEGs to my harddrive and create a DVD or VCD? Can I expect visible loss of quality on the DVD created?
Lots of questions. Hope this is the right forum as well.
i used since a long time your 1st method
take your mpeg2 files, author it with what you want and save on HD
if your video_TS file is more than 4.35 Go
use DVS Shrink to recompress it
for me, it's working well -
I can comment on #1 as that is the method I am currently using on a couple dozen home movies (VHS tapes actually). After capture, I run them through Ulead MovieFactory Disc Creator. IF they are over the size limit I output TS Folders. I then use Shrink, input the TS folders and compress to fit the disc.
Works great. I do agree with guns1inger that you will siffer a quality loss with method #2. Method #1 has little if any quality loss as long as you're reasonable (don't try to put 10 hours of TV on a disc).
compressing video filesize for storage
By azor in forum Video ConversionReplies: 18Last Post: 18th May 2011, 02:34 -
Coverting recorded TS or MPEG recorded from DVB card to XVid Avi...
By MohamedYousri in forum Newbie / General discussionsReplies: 4Last Post: 7th Nov 2010, 16:38 -
Cache storage of flash video?
By smooth88 in forum Video Streaming DownloadingReplies: 2Last Post: 6th Apr 2010, 23:27 -
Best storage media for audio (long term storage)
By The Sumerian in forum AudioReplies: 6Last Post: 6th Mar 2010, 12:15 -
Video data storage solution
By Diginosis1 in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2008, 08:59
