I have a bunch of Anime on my hdd that I want to put on DVD so I can free up hdd space. So far there hasn't been any problems for me converting 16:9 avi to 16:9 DVD but whenever I try to convert 4:3 avi to 4:3 DVD I can't get the picture to fit perfectly on my TV screen. The width (640) is okay and the height (480) is the problem I'm having. For some reason I can't get the height to be centered, the bottom part always gets cut off. When I adjust the height to 400 I get the bottom to fit but the top ends up with alot of room. Does anyone know how to adjust the height centering in TMPGenc?
Btw these are the settings I use for 4:3:
The original avi file as shown in GSpot: 640x480 (1.33:1) = [4:3]
Project Wizard -> DVD -> NTSC
Video Type: Non-Interlace
Aspect Ratio: 4:3 525 line (NTSC)
Other Settings -> Advanced -> Video arrange method -> Center (custom size) -> 640x480
I tried other settings like Center(keep aspect ratio), Full Screen, Full Screen(keep aspect ratio), Full Screen(keep aspect ratio 2) and all those don't work either. This problem with 4:3 conversion has plagued me for a long time already. I hope someone can assist me in solving this problem.
The further away I get from the things that I care about...
the less I care about how much further away I get... -
4:3 for DVD is a flag.
The res must be a compliant res:
720x480
704x480
352x480
352x240 not suggested, is deinterlaced
http://www.digitalfaq.com/convert/tmpgenc/tmpgencplus.htm
http://www.digitalfaq.com/capture/avivsmpeg.htm (stuff in last half of page)
http://www.digitalfaq.com/understandsource.htm (AR info)Want my help? Ask here! (not via PM!)
Are you saying if I set my custom size to 720x480 the picture will fit when I convert it to DVD?
Read.Want my help? Ask here! (not via PM!)
Okay, just done reading. That page explains the different resolutions associated with different forms of media and sources, but explains nothing about the TMPGenc problem I'm having. With understanding of AR in mind I'm still unable to get the vertical center to fit on my 20' tv. Even with the understanding of AR the problem is lying with TMPGenc not weather I undertstand AR or SAR.
try this, under "Other Settings"..."Advanced" tab:
maybe try the other settings under this tab too...
mastersmurfiejust a thought
mastersmurfie
converting mkv to avi + problems
By sgbd in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 13:53 -
Problems converting DVD to AVI, MP4
By azikiwee323 in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2009, 12:33 -
Problems converting Multiple .avi files w/ subtitles to DVD
By bwanis in forum MacReplies: 2Last Post: 30th Nov 2007, 13:23 -
Centering Movies/Videos
By streetracer096 in forum Newbie / General discussionsReplies: 5Last Post: 14th Jul 2007, 19:41 -
Loads of problems converting avi etc. to dvd please help!!
By mrd2007 in forum Video ConversionReplies: 9Last Post: 14th Jul 2007, 12:53
