I've made a DVD from a DV-camera...
I've used TMPGenc to encode the m2v and mp2. The m2v clip runs smoth and fine.
But if i author it in scenarist the clip is very jerky. I've both tried to run the vob files dirtely on drive and to burn it down on DVD, same result..
Anyone have any ideas?
/Anders
//Anders
Thanks for a promt reply...
Yea, it was set to bottom, and its not jerky all the time.. Just at some points.
/Anders//Anders -
Could be. You have two choices. Either
1. Run the 3dsmax scenes through VirtualDub and output interlaced footage and edit it back in,
or
2. Rerender the 3dsmax clips as interlaced footage.
Option 2 is the best option, however it is probably the most time consuming and least practical.Read my blog here.
Thanks will try
3rd option deinterlace DV footaqe?
I have some captions over the interlaced DV clip. Those captions are not interlaced, that can not create problems right?
/Anders//Anders -
You may compromise the quality of your DV footage if you deinterlace it. The problem you have is that the two fields do not match up exactly to make a frame. They are a fractions of a second apart in time (1/50th for PAL, almost 1/60th for NTSC). Deinterlacing will require a decision on your part. Do you a) throw away one field (and if so, which one ?) and stretch the remaining field to full height ?, or b) blend the fields together and hope they match up reasonably well ?
If the project in your editor is set to interlaced, then the output will be interlaced, regardless of the source. The 3D will look more jerky because it does not have 50 (or 60) fields, but rather 25 (or 30), each shown twice.
You could try applying a subtle motion blur to the 3d footage in the editor. It may help cover it up.Read my blog here.
Even the sound is out of sync to the from the picture in these shots. can that also be a result from this? It looks like the sound only is out of sync in the none interlace parts (3ds clips)
/Anders//Anders
Scenarist Mux Server Problem...Anyone?
By Thommers in forum Authoring (Blu-ray)Replies: 4Last Post: 11th Jun 2009, 13:06 -
Scenarist 4.3 subtitles problem
By paulspurrier in forum Authoring (Blu-ray)Replies: 1Last Post: 11th Jun 2009, 06:16 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 01:08 -
error when import subtitle in scenarist
By pcb in forum SubtitleReplies: 4Last Post: 17th Feb 2009, 05:38 -
Scenarist Menus
By nx01rules in forum Authoring (DVD)Replies: 5Last Post: 11th Nov 2008, 00:22
