Hi. Just added the NEC 2510 dvdrw to my pc as a slave drive.
I changed the little plug on the back of the drive from primary to slave. And my cd-rewriter is the primary drive.
Turned on the pc and the cd-rewriter (primary) is not showing. Only the dvd-rewriter is showing.
In My Computer - the dvd-rom drive is reading as
NEB DVD^RV ND 2410![]()
What could be the problem?
Results 1 to 9 of 9
BTW, this was an OEM drive so nothing came along with the drive.
Running Windows XP Pro. -
Originally Posted by guns1inger
What does cable select mean?
And how do I do that?
This is frustrating.
After the setup, the windows loading time had increased by 7x!! It takes about 1 whole minute for the loading. This happened after inserting the dvdrw.
1) I tried setting both the dvdrw and cdrw to "Cable Select." No luck. Still the windows take soooo long to load and the drive does not show up at all.
2) I have switched - dvdrw to primary and cdrw to slave. Still does not work.
3) I have switched back - cdrw to primary and dvdrw to slave. Only the dvdrw shows up but as NEB DVD 2410a (rather than 2510).
4) The dvdrw was very HOT when I was removing from the case.
What else would you recommend to do? I feel like contacting Newegg and getting the drive RMA. What do you think? -
Try installing each drive on a separate ide if you can.
Memorex 2510/2511 Blu-Ray Players -- PAL Playback
By dursman in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Feb 2009, 14:49 -
Memorex MBVD-2510 Blu-Ray player
By mightee in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Dec 2008, 15:36 -
Guide to fix Illegal Disc Error for NEC drive (possibly others)
By lucaschrist in forum DVD & Blu-ray WritersReplies: 10Last Post: 5th Apr 2008, 02:11 -
Win XP installed on slave drive!!! How???
By rijir2001 in forum ComputerReplies: 7Last Post: 4th Sep 2007, 10:25 -
slave drive seems dead, but cannot boot without it
By ted demen in forum ComputerReplies: 11Last Post: 13th Jun 2007, 08:54
