  1. Is anyone running Ulead DVD Moviefactory 2 SE or 3 with SP/2. I'm trying to use MovieFactory and it keeps crashing. The last time I used them they worked OK. The main changes I remember making since the last time I used MovieFactory are installing SP/2 and updates,Norton Updates and DVDlab trial version. I have upgraded Nero to version 6 but I don't know if it was before or after the last time I ran MovieFactory. I was going to try and remove SP/2 but it gave me a list of programs that may not run correctly if I do.
  2. Problem solved. I decided to go ahead and do a system restore from before I installed SP2 and my programs are working again.
  3. I finally found out what was really causing my problems with Movie Factory 2 and 3. At first I thought Windows SP2 update was the problem. The real cause of my problem was with the newest ATI MMC version. I think it's a problem with the codecs in MMC. I also found out Pinnacle Studio 8 stopped working. After uninstalling the newest ATI MMC everything is running OK with SP2 installed. If anyone is having trouble with Pinnacle or Ulead products this is something that may be of help.
