Hi all...
I am capturing some VHS tapes to my computer and having a problem. I keep having troubles getting the audio consistent. I have a SoundBlaster Live card and am recording through the Microphone in jack. Also tried the LineIn but it makes no difference. The problem I am having is that the audio is always slightly distorted. I have adjusted the Windows mixer controls but it won't help. Currently I am using ATI MMC 8.1 for capturing software. So far, I don't like this software at all. Can somebody throw some suggestions at me?
Cheers!
The software has nothing to do with it, MMC is pretty transparent to audio.
Be sure the DB boost is off the MIC.
Better yet, use internal AUX wiring.Want my help? Ask here! (not via PM!)
The DB boost is off.
I am not saying the software is the problem, just saying I don't like it (yet). Will the internal AUX wiring solve the problem? thanks LS -
Lordsmurf..Hooked up the AUX and problem solved.
Thanks for the help!!! You are the ATI man!
yamada DVR 9000 won't start :(
By mwg in forum DVD & Blu-ray RecordersReplies: 0Last Post: 28th Jan 2010, 09:24 -
Capturing VHS with Diamond AIW HD 3650PM
By justin81 in forum Capturing and VCRReplies: 1Last Post: 13th Jul 2009, 15:15 -
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 12:26 -
Logitech Quickcam 9000 Pro
By Tyler2000 in forum Newbie / General discussionsReplies: 2Last Post: 6th Nov 2008, 16:22 -
How can I burn a dvd with Vista/HP Pavillon 9000?
By STREETLIFE in forum Newbie / General discussionsReplies: 5Last Post: 20th May 2007, 19:15
