    Jul 2004
    West Chester, PA
    when ever I open a video with avisynth it comes up:
    avisynth open failure:
    The script's return value was not a video clip
    but when I open the video in virtualdub, it opens fine
  2. Post your AVISynth file so I can take a look at it.
    Jul 2004
    West Chester, PA
    AVISource=("C:\The.Matrix.DVDRip.XViD.ECHO.CD1.avi ")
    I'm just trying to open the file now, I would add other stuff later
  4. This won't fix your error message, but I'd suggest renaming the file... or at least changing it in your post.
    Darryl
  5. Remove the =
    The way you wrote it you are trying to assign something to a variable named avisource, not opening a video with the avisource function.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If in doubt, Google it.
  7. Try this
    avisource("xxxx.avi")
    instead of this
    avisource=("xxxx.avi")
    or you could do this
    movie=avisource("xxxx.avi")
    return movie
    Darryl
    Jul 2004
    West Chester, PA
    thanx you guys that worked!
    that was weird I've always used an = sign before and It would work
