ok, now I was thinking about something to further increase video quality when converting divx to vcd or svcd mpeg,
since both divx and mpeg use heavy inter-frame compression
in the theory when the same processes are used twice doesn't that decrease quality?
so wouldn't it be better if I decompressed my a divx movie with huffy or mjpeg codec at a larger resoultion?
then use that file to make a vcd compliant mpeg?
I know that I might of stated that wrong but does someone know what I mean? and could they help me out?,
thanks
I doubt it. I believe it would lead to more quality loss, since you would not only get those 2 heavy processes, but you would also get the process of decompressing the file to huffy (which would be a third conversion, which I believe would lead to more quality loss)
DivX is a lossy codec, so you can not refresh the quality by decompessing.
DivX -> AVI/MPEG - stumped!
By ouroboros10 in forum Video ConversionReplies: 4Last Post: 7th Apr 2009, 13:23 -
DVB-S MPEG -> DivX
By geohei in forum Video ConversionReplies: 8Last Post: 11th Oct 2008, 11:11 -
Firewire to divx/mpeg-4
By exon in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2008, 19:59 -
Divx has subtitles and I want them permanently on an MPEG, but....
By darthvonpokemon in forum SubtitleReplies: 2Last Post: 14th Jun 2008, 11:45 -
Avi Or Mpeg to Xivd/Divx
By Castor troy in forum Video ConversionReplies: 2Last Post: 27th May 2007, 10:24
