after some months of comparatively no problems at all with canopus pro encoder i have now hit a wall it seems , some way onto an encoding project i get the canopus error message " inactivity timeout detected conversion was aborted " has anyone any idea what this is or why i should suddenly get ti after so many successful jobs and how do i rectify this issue please anyone ?
much obliged to any practical helpful suggestions on this one![]()
Have you updated to SP2 just before this trouble started. There was another thread in the computer section where windows wasn't communicting with a DV cam. Uninstalling SP2 fixed it.
hi thanks a lot for the reply firstly , well i looked in my add/remove list couldnt see service pack 2 and dont recall installing it recently , i found a wr 2.0 which a google sessions seemed to reveal was not an essential thing to have on my pc ( some kind of spyware etc ) and there was another one the other day called bullseye or something which i removed also , it has to be a coincidence ( i hope ) but i could possibily trace the canopus glitch to when that was removed , but if it was some kind of spyware obviously seems an impossible theory , so i am a bit stuck now , i was hoping there were some settings in canopus i could change .
thanks again -
Sorry, you are reffering to software aren't you. I was thinking it was the capture device. If it is the capture device read on if not ignore it.
SP2 refers to Windows Service Pack 2, if you have windows set to to automatically download updates it may have installed in the background. I'm not sure if it will show up in the add/remove list. You can check to see if it's installed by going to control panel>system. Under the general tab at the top it will list what version of XP you have. you can remove it by going to system restore and finding the point where it was installed.
I don't know that this is what the problem is. It's just a suggestion since it's similar to the one with the cam.
As for your spyware if you don't have it get adaware and spybot which will remove them from your system. Both are free, make sure you update them after you install them before scanning. -
hi once again thanks there for your detailed response , yes i checked as you advised and its got service pack 2 v. 2082 listed , i am not at all sure when or how long i have had this on though , but i wil lcheck on those removal programs too , been meaning to have a clean up for a while with them . i thought there might have been a few people reporting similar problem as mine but as yet no one has .
all the best to ya there !
avcodec_decode_video Timeout
By james_watt20 in forum ProgrammingReplies: 0Last Post: 18th Jan 2012, 03:03 -
AVISynth Error DirectShowSource: Timeout waiting for graph to start - .m2ts
By onesikgypo in forum Video ConversionReplies: 2Last Post: 22nd Jun 2010, 22:30 -
RipBot error -- DirectShowSource : Timeout waiting for graph to start
By crankharder in forum Blu-ray RippingReplies: 10Last Post: 20th May 2010, 10:19 -
uTorrent inactivity?
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 4th May 2009, 23:45 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 04:56
