Hello all,
I use Sub Workshop 2.51 to convert a set of subtitles of Greek and Slovak into the appropriate format which DVD Architect imports.
When I load them up in SW 2.51 it shows everything fine and the text is ok. When I Export it , then I load it up into DVDA, then all of a sudden there is no correct display of the fonts anymore.
Loading them into Notepad shows up that they look also the same not correct way.
What step am I missing to have them shown up correctly in my Authoring solution?
I also changed the font type within notepad to Greek and saved as Unicode but that didnt help either.![]()
Please help.
Results 1 to 1 of 1
Greek subtitles problem
By MultiNikos in forum SubtitleReplies: 39Last Post: 1st Oct 2017, 02:51 -
unreadable greek subtitles
By ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 08:45 -
By ioakim2an in forum SubtitleReplies: 1Last Post: 17th Aug 2010, 06:52 -
Problem with GREEK SUBTITLES
By neroman00 in forum Video ConversionReplies: 3Last Post: 29th Dec 2009, 09:48 -
GREEK sUBTITLES HELP.
By AndreasTorous in forum ffmpegX general discussionReplies: 1Last Post: 10th May 2007, 12:07
