Hi Im using dvdsanta to convert some films back to dvd from divx and svcd files but I m having problems. The finished files when burned play the film as a mirrored image ie the credits are back to front and the floor is where the sky should be! Any ideas what has happened? I ve burned a couple ok and thought the software was great now every one is having this problem. Any advice would be greatly appreciated.
Sounds like a codec problem. Make sure you have the latest codecs installed.
I had this problem with Divx 3 files, but it went away after I reinstalled.
Does the source file play correctly in Windows media player?
Newbie only know how to use DVDSanta, but it won't convert some videos
By HartsVideo in forum Video ConversionReplies: 18Last Post: 19th Oct 2008, 19:42 -
dvdsanta problem
By bountylord in forum Newbie / General discussionsReplies: 10Last Post: 13th Jan 2008, 09:57 -
Does dvdSanta Have Audio?
By ineedamakedvds in forum AudioReplies: 8Last Post: 2nd Aug 2007, 16:57
