Copy of DVD(5) to a DVD-r and remove some parts???
I want to copy a DVD5 to a DVD-r BUT I don't want everything on the original DVD!!! For example, remove some traliers or shit.
I don't want to make a whole new DVD with advanced editing, I just want to deselect some parts.
Can't find it anyware..
HOW DO I DO THIS???
seyah
Results 1 to 15 of 15
Check the guides section to the left. There are plenty of step-by-step pages there.
But then I won't get the menysystem just the files in a row, I want the same menysystem..Originally Posted by EGrier
Yeah I have looked but I havent found one that fits me yet... its full copy or just a copy of the main movie... if someone can find a guide for me that would be grrreat..Originally Posted by andkiich
Gonna go through the guides one more time..
tnx guys -
You may need to find out for yourself but, I think Nero Recode 2 will allow you to remove parts of the DVD and still retain the menu. There was a guide a while back that showed you how to do it with DVDFab and DVDShrink. I have tried it and it does work. (Removing extras, trailers, etc.)
Good luck -
I'm inlove. If it workes for me u're the king, are u interested in my ftp? maby can trady some shit? seyah -
I've used DVD Shrink, Intervideo's DVD Copy2 and CloneDVD2... all three allow 'parts' of the movie to be removed, if needed.
But with a DVD5 you can do a direct copy of the contents to a blank DVD-R -
Mandolito,
look at this link: https://www.videohelp.com/forum/viewtopic.php?t=185976&highlight=noki
this is the one that I have used and it worked for me. -
I ripped the dvd to my HD with no compressions then I used clone2dvd to remove some trailers.. but there is still intro and a little other shit left..
Why do you care if they are there? You can do a direct dopy if it is a DVD 5. If you are trying to save space just put all the extras as still images in DVD Shrink.
This plan is so bad, it must be one of ours. -
The thing is that I don't want the ******* ugly "do not copy this DVD.. bla bla bla" info in the beginning, but it doesnt matter, I'm satisfied for nowOriginally Posted by Darth Paris
I live by IfoEdit. It will remove the FBI crap, and anything else you want. There are plenty of guides on IfoEdit.
Also some people may find IfoEdit a bit confusing, if you happen to fall into that group you can try DVD Stripper, if it's still around. It uses IfoEdit, for you. All you have to do is click on what you don't want, and it takes care of the rest. -
Cool, tnx, willl try DVD stripper, and if I am not satisfied I will try IfoEditOriginally Posted by wolv6769
easy way to remove alpha logos (with no opaque parts)
By dumbledore in forum EditingReplies: 1Last Post: 16th Feb 2010, 19:22 -
Remove certain parts from MPEG-2 [no transcoding]?
By therock003 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2010, 14:49 -
Trying to copy VHS to DVD, but color is black and white at parts!
By MikeyA in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2009, 18:26 -
how to edit/manipulate .exe files to remove parts?
By Xylob the Destroyer in forum ComputerReplies: 5Last Post: 8th Nov 2008, 15:56 -
Only to copy selcted parts from a DVD
By aslan in forum Newbie / General discussionsReplies: 4Last Post: 31st Oct 2007, 10:03
