  1. Didn't notice the change in the change log but it seems they've removed the option to make an image of a dvd. I used to find this option useful so I could automate the process instead of using IMGTool afterwards. Was this option just hidden or does anyone else see the same problem? Thanks!
    -redfive
  2. Member JimJohnD's Avatar
    May 2001
    Ohio U.S.A.
    1. From the main menu select "Project"
    2. Select "Burn DVD..."
    3. Select the "Burn" tab.
    4. Check the "Create Image On Harddrive" checkbox.
    5. Click "Write". You will be prompted for an image filename and then it creates it for you.
    That should be it Great program, can't wait to upgrade to Pro...
    Hope this helps.
    JimJohnD
  3. Thanks for the tip! It just sucks that it's not in the post build options now. This is not much different than just compiling it with IMGTool.
  4. Member JimJohnD's Avatar
    May 2001
    Ohio U.S.A.
    Well, from what I can tell you have already done the best thing you can,
    http://www.mmbforums.com/modules.php?name=Forums&file=viewtopic&t=7357
    Oscar (the author of DVDLab) really listens to his users. That's one of the best things about the app. See what kind of feedback you get at the MMBForums site.
