  1. Member Tool Man's Avatar
    N. Ireland
    Just ordered myself an LG 4120-B burner. It takes DVD-RAM, but not the caddy type im told. I want to go out and buy some DVD-RAM discs for backing up, but can someone tell me the difference in the types?
    i.e type I, type II...which ones can and can't be removed from the caddy?
    Obviously I need the ones that CAN be removed, because the LG won't take the caddy.
    Thanks...
    We'll be right back after these messages from Binford!
  2. Maybe all can be removed from their caddy, but why buy discs with caddy when you don't need the caddy?
    10110101100111012011 <- The bug Bill doesn't talk about.
  3. No you can't take some of them out of the caddy.
    Why don't you get single sided ones? They are speed rated too, 1x, 2x....
  4. Member Tool Man's Avatar
    N. Ireland
    Thanks guys. I didn't know RAM discs could be bought 'caddyless'. But I got some now.
