I hope I am in the correct forum. How do I get a segment of a clip to play over (loop) a certain number of times and the be able to burn it on to a DVD.
What software do I need and I would be appreciative if someone can point me (or show me how) in the direction of a guide.
Thanks in advance for all replies.
If you do not learn from someone's knowledge and experience, then you are doing it the hard way
You want to be able to select the number of times to play and then have it play that many times?
OR
do you want to just dupe the clip, say, 5 times and then burn that to the DVD. If the later you can use pretty much any editor to copy and then paste the content X number of times ... create MPEG adn then burn to DVD. I edit in MPEG and use Womple Video Wizard.
Turn off Looping
By pepegot1 in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Nov 2011, 18:02 -
Bat file not looping?
By sambat in forum ComputerReplies: 5Last Post: 26th Feb 2011, 14:58 -
looping video for menu
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 23rd May 2009, 07:03 -
Specific looping?
By Koron in forum Newbie / General discussionsReplies: 8Last Post: 4th Sep 2008, 16:32 -
Looping DVD with no menu
By SCDVD in forum Authoring (DVD)Replies: 7Last Post: 21st Feb 2008, 20:12
