Hello
On my desktop computer I can play MKV files and on my laptop not, on my laptop computer I have a need for a dvsd codec to be able to play an AVI file captured from a DV camera using adobe premiere 7.
Basically I have a lot of codec problems, is there a universal codec pack available on this site or somewhere else ?
I have looked in the codec section of the site but nothing about dvsd and I have installed the matroska pack on both computers and it works on 1 but not on the other....
Thanks for the help
Originally Posted by txl
DVSD is probably a DV-Avi file. WIN XP includes the MS DV codec (not sure about other vers of windows). If you need an alternative there are free ones available from Canopus (playback only) and Panasonic (playback and encode) in the tools section. -
Hello,
After converting the AVI file to DV2 format I can now play file using WMP but virtualdub won't open it and I need to extract JPG frames....
Is there a way to extract still frames and save them as JPG using WMP ?
Also a great tool would be one that gives mùe the COMPLETE list of codecs required to play a file and which are currently installed on the machine and which ones are needed
Thanks a lot -
ok, thanks for the tools,
I don't know in which format I can convert this uncompressed AVI file coming out of a SONy DV camera to be able to play it in virtualdub so i can extract these damned JPG frames....
Any tip would be welcomed,
thanks a lot -
In order to open in virtualdub, install the Panasonic DV codec and vdub will open them fine.
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 21:34 -
what codecs do I need?
By johnsees in forum Newbie / General discussionsReplies: 19Last Post: 23rd Jul 2010, 08:53 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
