I have an ATI AIW 7500 Radeon and have downloaded the latest MMC 9.02 and can't figure out where Guide Plus+ is that is mentioned a lot here. If it is free, I'd like to use it instead of the trial version of Beyond TV 3. Is it a separate download from MMC or do you have to buy it?
I didn't know that system was still around. Used to be published in the TV Guide. Here's a link that will give you some up to date info. http://mirror.ati.com/products/faqs/guideplusfaq.html
You can find more with a Google search of 'Gemstar Guide Plus+' -
I have the AIW 7500 and it was on the original install disk. You may have used the "Custom" install and failed to check it. I always use the "Recomended" install in it shows up along with that useless Hydravision. After installation I uninstall those two programs. I don't watch TV on the computer and I have no idea what the purpose of Hydravision is.
If it works, don't fix it. -
If I remember right it's only on the original ATI install cd and not available for download. You should be able to buy the cd from ATI.
Ok, I got tired of people not being able to find the Gemstar Guide Plus+ software online so I have made it available for download at:
https://home.comcast.net/~djmattyb/GemstarGuidePlus.zip
dj matty b
Numpty's Guide Please
By Dan Dare in forum Media Center PC / MediaCentersReplies: 7Last Post: 10th Dec 2008, 02:55 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 11:34 -
guide for ssa
By pcb in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2008, 21:42 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 23:34 -
How to use Linux? Guide
By mjack425 in forum ComputerReplies: 2Last Post: 24th May 2007, 23:55
