Results 1 to 9 of 9
    Jan 2004
    Queens
    Hi. Some help please. Is it posible to rip two movies to your HDD at the same time? I use the latest dvdshrink and I'm trying to backup my brothers 50 owned movies and I'm trying to do it as quick as possible. Thanks for any advice.
  2. Member Forum Troll's Avatar
    Oct 2003
    Right behind you
    It would probably be slow as molasses, assuming you are writing both rips to the same hard drive, but it mite be bearable if ya have 2 DVD drives and rip each to a separate hard drive.
    You are in breach of the forum rules and are being banned. Do not post false information.
    /Moderator John Q. Publik
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, with 2 DVD readers, 2 physical HDD and sufficent CPU power, you might gain some compared to ripping them one by one. With just one HDD, it will just slow the process down, as the HDD heads will have to skip and jump all the time...
    /Mats
  4. How long does it take you to rip a DVD? I use DVDshrink and rip a full disc is about ten to twelve minutes using my LiteON LTD163S or LTD166D DVD drives.
  5. dual layer times and single layer times would be useful to me, too
    Jan 2004
    Queens
    I guess I should've mentioned my system specs. I have A Pentium 4 1.8 MHz. I have 250G WD HDD, 74G HDD, 40G HDD. I appreciate the help guys. I can always rely on good info on these forums. Thanks
  7. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    If you are backing them up for your brother, not much you can do about time, since they will both be cpu intensive.
    If you are copying them from your brother, you should have patience anyway. You're getting free movies.
    Just my opinion, but I think it's the latter.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    please post ripping in the dvd to dvdr forum. moving you.
  9. Banned
    May 2003
    Massachusetts
    It might be a LITTLE faster, but with your machine? Probably marginal.
    - Gurm
