Hi,
I would like to make analog and digital capture and tv/fm tuning. I will
start using Windows but would like to switch to Linux later.
Concerning the compatibility with Linux, are there cards that should be
preferred/avoided?
I am tended to buy a tv/fm tuner and analog capture card plus a firewire
card. For the first card I am considering Pinnacle PCTV Pro or Hauppauge
WinTV-Radio. Do you have a positive/negative Linux experience with
these or similar cards? Do you suggest another one? Is hardware encoding
likely to avoid or add problems for the usage with Linux?
Thanks in advance,
apol
I have tried both the Pinnacle PCTV-USB2 and the Hauupauge WinTV USB2 under Windows.
My recommendation is to avoid the Pinnacle device altogether. It doesn't work properly.
With Hauppauge, I've had some bad experience 3 years ago with the WinTV-FM Tuner-Capture card. The drivers were poor and the whole thing unstable.
I have recently replaced the Pinnacle (that died) with a Hauppauge USB device. It's working very well, the turer quality is much better than the Pinnacle (almost as good as my Panasonic VCR's tuner). The radio is very sensitive and very good in audio quality and discrimination (much better than my 15 years old deck Pioneer digital tuner).
Your initial decision should be whether to go for an internal or for an external device. Of course, since you want to move to Linux, check driver availability for that as well.The more I learn, the more I come to realize how little it is I know. -
I had a Hauppauge Win-TV FM PCI card. The card is OK but the Windows driver does not support S3 standy mode. So, I choose another TV card instead.
Hauppauge does have Linux support.
http://www.hauppauge.com/html/sw_wcst.htm
Please go here and there are many reviews on tv cards.
http://www.tv-cards.com/ -
My WinTV USB2 works fine with S-Video but audio does not. When trying to use with Intervideo WinDVD Creator 2 it freezes and I don't know if its the drivers or the software. If I switch to have audio not thru WinTV but thru the system audio it works but its choppy video. Anyone else with this problem? How do I get the radio to work?
Originally Posted by SaSi -
Regular Hauppauge WinTV cards (vs. PVR, etc.) actually work rather better in Linux than in Windows. My last two distros have detected the cards and installed support automatically.
Video Capture PCI / USB recommendation?
By harky in forum Capturing and VCRReplies: 0Last Post: 6th Mar 2012, 20:04 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum Capturing and VCRReplies: 0Last Post: 21st Sep 2010, 06:50 -
Recommendation of Video Capture Software for WinXP
By opey in forum Capturing and VCRReplies: 3Last Post: 4th May 2010, 03:16 -
I Have Nero 7 Ultra but Need Video Capture Device Recommendation
By Classic '57 in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2009, 18:45 -
Need recommendation for TV tuner card
By Djinn252 in forum Newbie / General discussionsReplies: 20Last Post: 27th Jul 2008, 04:30
