Hi Folks,
I'm using DVD Workshop 2 to author my DVDs. The input is usually from SVCD files (480x576) that are not DVD compliant. I tried to patch the first header to 352x576... worked fine until recent days but now, every time I import an MPEG file (originally 480) patched to 352, 1/4 right of the picture is missing... it's driving me crazy and I'd be happy if someone has an idea to fix that. I don't want to re-encode the video to DVD compliant. Is there a way to turn off the "convert to disc template" option ?
Meanwhile, I also saw that there is in "Disc template manager" a way to design new templates. Is there a possibility to activate the option of "user-defined frame size (see picture)... perhaps by tweaking the dvdws.ini file or other *.ini file ?
Perhaps in that way, I can force DVDWS to accept my 480x576, without patching, without loosing some image and without re-encoding ?
Thanks a lot,
CJ
Results 1 to 1 of 1
Change VOB Resolution
By Simmons in forum Video ConversionReplies: 4Last Post: 30th Aug 2011, 08:37 -
Change video resolution
By Browneyd in forum EditingReplies: 5Last Post: 11th Jan 2011, 11:34 -
Change resolution from 235:1 to 16:9
By ThaiJan in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 15:16 -
How do I change video Resolution
By mmkk in forum Video ConversionReplies: 7Last Post: 31st Aug 2009, 18:33 -
Change resolution without recompressing?
By StoneGold in forum Video ConversionReplies: 9Last Post: 30th Sep 2007, 09:02
