With version 2.66, CCE had a check box to select Top field encoding in the Video settings form.
With version 2.67, this checkbox disappeared. A new parameter appeared - offset line - but it doesn't seem to be equivalent.
Was unable to make sense by reading the manual. No reference or information on field order exists for 2.67.
Does anyone know how to select this in version 2.67?
Results 1 to 12 of 12
The more I learn, the more I come to realize how little it is I know.
Offset line 1 if your video is lower field first.
Offset line 0 if your video is upper field first. -
CCE will always show TFF , if source is BFF , CCE will offset the the first line (if you set offset correctly) ..
btw - canopus will also offset the first line - so it doesnt mater which way you have the target set to , as long as the source is set correctly ..
pal is often best to set to TFF anyway ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
No luck, I'm afraid...
Encoded a small clip (that is BFF) using both 0 and 1. Both m2v files came out as TFF marked.The more I learn, the more I come to realize how little it is I know. -
see my post aboveOriginally Posted by SaSi"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Well, it's strange but this doesn't work.
Encoding an AVI file with MC or Tmpgenc, the setting for field order is reflected in the encoded .m2v file as verified by Restream and DVDLab's mpeg browser.
Of course, setting the field order incorrectly results in flickering playback.
With CCE, no matter what value I give to the offset line parameter, both Restream and DVDLab show the resulting mpeg video to be TFF.
The resulting DVD playback on TV is unwatchable.
Changing the Field order flag of the mpeg file with restream corrects this.
Will have to investigate this further. Will try the older CCE version to find out what's wrong.The more I learn, the more I come to realize how little it is I know. -
Well, like BJ_M wrote, CCE always creates MPEG-2 files with the TFF flag set. If you set offset line to 1, CCE shifts the video up by one line. Shifting the video up (or down) like that changes the field order of the source file. A few possibilities:
- If your source is TFF and you set offset line to 1 the field order will be changed to BFF but your MPEG-2 file will still be flagged as TFF. Jerky playback on a TV.
- If your source is TFF and you set offset line to 0 the field order will remain TFF and your MPEG-2 file will be flagged as TFF. Normal playback on a TV.
- If your source is BFF and you set offset line to 0 the field order will remain BFF but your MPEG-2 file will be flagged as TFF. Jerky playback on a TV.
- If your source is BFF and you set offset line to 1 the field order will be changed to TFF and your MPEG-2 file will be flagged as TFF. Normal playback on a TV. -
you should set it to 0 also for progressive encoding , but remember to set the progressive flag also ....
Woah!!!
Tried it with a value of 50. Video was shifted up by 50 (I didn't count) lines and what was cropped from the top appeared in the bottom.
Now, this is a nice way to handle field order. All video is generated as TFF this way.
Thanks guys. You really saved my day (and night sleep
By the way, shifting the video up by 2 (or 50) lines doesn't change the field order. It has to be an odd number to change the field order.
Yes, I know. But isn't it nice to play around, once you discover a feature?Originally Posted by erratic
My only question is why did they bother implementing such a feature in the first place. Why would someone want to shift the frame by any number of lines?The more I learn, the more I come to realize how little it is I know.
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
Reconciling different Field Order
By vegasarian in forum EditingReplies: 8Last Post: 14th Mar 2009, 12:43 -
field order and cce
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2008, 17:11 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14 -
Need to change field order
By Loko in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 21:32
