I was using TMPEGENC to encode my avi files from slide show movie maker and files converted to avi by Stoik Video Converter. After my trial ran out I was going to buy TMPGENC but then I discovered that BBMPEG would do AVI2MPEG2. I just tried to convert a whole bunch of avis with it but all of them are bad. First off it says MPEG2 but the only output it does is mpeg-1. Is there any other good free program out there that will convert avi to mpeg 2 (dvd)?
I had downloaded that & tried it. First I ran it with Quenc and didn't encode the audio, went fine but when I checked the output files in the VIDEO_TS folder, there were no files. Is there a way for it to create just avi to mpeg2 (dvd) files? I then tried with the audio conversion (the video file is only 10 seconds long by the way) and I started converting. It just sat there with BeSweet open forever trying to convert the audio. Is there any guides for using DVD2SVCD or is there anyway I can fix this so I can just get avi (with XVID PCM) to MPEG-2 d1 NTSC DVD Compliant?
Mpeg vs. Avi for VHS to DVD
By smartel in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2011, 11:39 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
dvd to avi or mpeg
By AeR0 in forum Video ConversionReplies: 3Last Post: 22nd Jan 2010, 13:45 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DVD to MPEG-2/AVI
By Nitro89 in forum DVD RippingReplies: 21Last Post: 14th Apr 2008, 15:17
