Hi!
I just have a tape that I'm trying to capture. However, in some parts, the image shakes, seems like a ghost.
I have read some posts telling that I should use a TBC (Time Base Correction). But what is a TBC??
Is it an equipment? Or a special cable? What??![]()
And how much does it cost, approximately?
Best regards,
Joelson. -
From the <== glossary on the left
Time Base Corrector
A hardware device used to remove or mask variations in the video synchronizing signals, which can result in "skewing" and other distortions in the video image generated by unavoidable mechanical inaccuracies in helical scan recorders. This is accomplished by automatically delaying the video signal so that each line starts at the proper time. In capturing a TBC is used to 'clean up' analog tape problems and may assist in the capture of old VHS tapes when used betwee a VCR and capture card. Hardware TBCs can be expensive.
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 19:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 09:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 11:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 08:29
