The question: For some reason or another my audio plug in in the back of my computer no longer works. Are they hard to change, can I even do that?
*Everything below this point doesn't need to be read. :P*
I was playing Counter Strike and my audio decides to go out. This had happened once before and all I had to do to fix it was restart the computer, even then the audio came back before the computer had restarted. However, this time I wasn't so lucky. I decided to install the latest audio drivers before restarting, and the audio still didn't come back. After trying numerous ideas nothing worked. Finally I decided to try the audio port in my 7 in 1 media card, success!
Originally Posted by IAIHMB
You need a soldering iron and a pair of small pliers. Desolder the old one and take it down to Radio Shack or similar, show it to the salesman and tell him you want something with the same "pinout", and just solder the new one in. You may have to clean out the thru-holes in the board, but just remember to not leave the heat on the board longer than needed and you'll be OK -
Whoa whoa whoa, wait a minute. I have onboard audio, doesn't that mean it is integrated with the motherboard? This sounds like it could get complicating.
Sounds like a much better idea for me then.
Now I have 2 more questions, I think. :P
-Are audio cards hard to install? My expierence with this only goes as far as installing a slave hard disk, another stick of RAM, a video card and a power supply.
-Would it be hard to get my 7 in 1 media card to run off from the new audio card?
This damn computer gets more expensive weekly. -
you could get a cheapo 5.1 souncard.
Most of them are pci. You just slide it in the slot, and screw it in. Then install the driver software.
I don't see any reason why it wouldn't work with your new audio card.
Audio/Mic problem during filming, need a solution..
By sdsumike619 in forum AudioReplies: 16Last Post: 31st Jan 2012, 18:17 -
Need some advice for an advanced recording solution. Intensity Pro
By lodiams in forum Capturing and VCRReplies: 3Last Post: 23rd Apr 2011, 02:05 -
Need advice on best capturing solution
By vitalic in forum Capturing and VCRReplies: 22Last Post: 15th Feb 2011, 13:11 -
Solution Advice requested. Copy several movies at once?
By ehcah in forum Newbie / General discussionsReplies: 10Last Post: 3rd Dec 2010, 20:31 -
Video Solution / Advice
By air@icubed.com in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2008, 18:53
