Ok, I know this question has been asked a million times, but I have tried everything I can think of and here is what I get:
I am converting RM files to AVI using EO Video. I have several different South Park episodes I am canverting. Some Convert great, others have stretched audio. Here is the part I don't get. When I split the audio in VDub into WAV it is the exact same length as the video file. So I use the Wav file as the sound and the avi as the Video file in TMPGEnc and what do I get? A movie with the soud out of sync. Is this simply because RM files are peices of crap and some work and some don't? Any thoughts on this would be appreciated.
Well, that could be it..
but maybe your .rm files are encoded with some odd frame rate, and when TMPGenc tries to convert it to a "normal" framerate, it will just drop a frame every now and then, which could make the audio go out of sync. -
yea, it's possible. Find out what the current framerate of the .rm file is, and if you are just going to watch it on your computer make sure the program (never tried EO Video, but should be possible) doesn't try to change the framerate (Tell it to use exactly thesame framerate as the .rm file).
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
problem with mkv audio sync
By movelikeme in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2010, 17:49 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
