Results 1 to 20 of 20
  1. Member Treebeard's Avatar
    Aug 2002
    http://www.blessa.com/64-equals-65.gif
    pretty strange, but cool
  2. Anonymous
    Guest
    hard to figure out.
  3. I had to watch that a few times... wondering if when they sliced the areas they added one full square based on their cut locations... would like to watch that slower.
  4. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    I posted this in the one thread about stumping eachother with math...I forget the name.
    I can tell you where the flaw lies. It is an example we go through in Trig every year.
  5. Member Treebeard's Avatar
    Aug 2002
    Ok, tell.
  6. Member northcat_8's Avatar
    Mar 2003
    When the triangles and the trapazoids are cut out, they are cut with straight lines, however when the large side of the triangles are placed at the end of the trapezoids, the line is not a straight line, it is actually a little under 180 degrees, creating a slight gap between the newly created larger triangles, the gap that is difficult to see has one unit of area.
    8)
  7. I bow to you brainiacness
  8. Banned
    Jan 2004
    Going in Circles
    WTH?
  9. BRAINIAC (smartest person on earth) -- NESS added for emphasis
    http://theages.superman.ws/Encyclopaedia/brainiac.php
  10. Banned
    Jan 2004
    Going in Circles
    I was talking about 64=65
    I know what a braniac is.
    Thanks anyway though.
  11. Whoops.... thought you weren't up on you Superman lore.
  12. Banned
    Jan 2004
    Going in Circles
    If I remember correctly, braniac was in the dead again storyline in the comics.
  13. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    8)
    Spot the maths teacher ....
    If in doubt, Google it.
  14. Video Restorer lordsmurf's Avatar
    Tan ... something you get at the beach.
  15. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    What about Sin - I'm not touching it because of religion.
  16. Member northcat_8's Avatar
    Mar 2003
    NOOOOO don't "Sin"....if you must 'sin' then use "COS"....that way you have a partner
  17. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Sin, Cos and Tan - that reminds me of the good old days doing trig.
  18. Member northcat_8's Avatar
    Mar 2003
    That's good...it is trig
  19. Trig was one thing I was good at in maths lessons. It made good sense to me. The rest was gibberish!
  20. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I had to endure it all through secondary school and then all through university. I studied mechanical/electrical engineering and trig was a big part of the maths component of that.
    I'm glad I don't have to use it now.
