Up to now I have been using DVDShrink for doing straight backups of my DVDs, is this the best tool for the job?
Does anyone recommend any other tool to do the job?
Results 1 to 17 of 17
To make "straight backups" of your CD or DVD use the software that came with your burner (ie: Roxio or Nero)... it will be faster that Decrypter or Shrink.
Assuming that the disc isn't CSS protected, of course.. In which case a DeCSS'able ripper is needed (ie: DVDDecrypter); or an intermediate such as AnyDVD, then feed it into Nero/Roxio/etc.
you been smoking again, DVD_Ripper ?
I didn't know nero or roxio could decrypt CSS.
DVDShrink or DVD2One are my tools of choice. If I have a DVD-5 I just use DVDDecrypter ISO Read / DVD Decrypter ISO Write.If in doubt, Google it. -
I always use DVDShrink and DVDDecrypter, but since the need has arisen to make backups with a second layer of space, I've also been trying to find something that allows me to specify a time for the layer change, or at least more reliably burn the discs. DL burning is still something that needs to be worked out from the looks of it.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
Dvd Shrink is the Best, Don't fix something thats not broke.
If Man Made It, Man Can Copy It. -
Since I tend to do movie-only backups even when the target is a DL, it never crossed my mind to not remove the layer break. I would have thought that the break would have been placed on its own by the program... I guess I lost that Windoze-infected cynicism for a moment. <sigh>
Have you tried using Shrink with the 'Remove Layer Break" disabled in Preferences ? Then writing to an ISO. This should retain the original break point, should it not ?No DVD can withstand the power of DVDShrink along with AnyDVD!
Originally Posted by jonchill
DVD9 to DVD5 keeping menus, extras and all soundtracks and subtitles
then there are some other tools besides (NOT instead) DVDShrink you could use.
First that comes to mind is DVDRebuilder. I use it when the film needs more than 80% compression. It does take a lot longer though.
Are you still interested in this? Could you clarify "straight backups"? Do you really want keep everything in every case? If not, there are more options...It wasn't me.
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
Need Quality Converting, Copying and Editing Software?
By BassJunkie in forum Video ConversionReplies: 24Last Post: 19th Jul 2009, 02:49 -
Re:Copying a dvd rw
By lol23 in forum Authoring (DVD)Replies: 5Last Post: 18th Oct 2007, 05:54 -
Best DVD to DVDR Copying Software
By mattstan in forum DVD RippingReplies: 1Last Post: 18th Aug 2007, 09:24
