  1. Just bought this DVD player and can't seem to find a region code for it. I tried codes for 130 and 150, but they don't seem to work.
    Please Help, Thanks.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Please don't use ALL CAPS.
    Check this LINK
    There may be somthing there for your player. Just enter your model number.
    Kevin
  3. sorry about the caps.
    I've been all over this site and have had no luck.
    thanks anyway.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    No problem. Best of luck on your hunt.
    Kevin
    --You could always get a cheap $40 USD player that is known to be region free--
