    Nov 2003
    Australia
    Out of a bunch of processing and editing video tools I have found the best results so far are with Virtual Dub however I can't see any option to join the sequence of avi files I get in output mode. Does anyone know if such option is available and if not what would be the next best option to join AVI files thanks
  2. Are you joining them to take them through to dvd?
    If it's wet, drink it
    My DVD Collection
  3. Use File -> Open to open the first file, then File -> Append AVI segment to append the subsequent file(s).
    If you name your files with numbers like:
    file00.avi
    file01.avi
    file02.avi
    file03.avi
    file04.avi
    VirtualDub can automatically append all the additional files (controlled by a checkbox on the append file dialog).
    Nov 2003
    Australia
    Yes I am aiming at creating a dvd
    Thank you junkmalle for this fgreat tip
  5. You're welcome, Doc.
