22 nov. 2001 version 1.0.4 build 1
- Added support for converting CIF images to bin/cue using CDMage B5
- Fixed the MADPlay endless repeat bug (Thanks to those who reported this bug)
- Fixed the CCE settings bug. The settings of Linear quantizer scale, Zigzag scanning order, Upper field first and Progressive frames was not transferred to CCE, sorry. (Thanks to Ruben for pointing this out.)
- Added the possibility of executing a program/batch file of your choice per cd image. Still pretty much beta.
- Fixed the ascync problem with PVA files by demuxing the PVA stream instead of making a PS stream. You must use Version 2.0.10. (Thanks to Stars55 for the PVA stream)
- Added the possibility of using the mp2 stream in a PVA without any conversion. That could save you an hour or two.
- Added support for MPEGAV when usinf VCDXBuild and I-Author. (This is non-compliant SVCD)
- Added the possibility to change the bbMPEG video and Audio offsets. But don't change them unless you have a good reason to do so.
- Extended the maximum overlap from 5 to 30 seconds.
- Appending to the log when doing Crash Recovery instead of overwriting it.
- Added better Error messages. No more "IO Error 112" message, instead you get a "Disk is full message"
- Fixed a bug in Crash Recovery when using 2 audio streams
- Added DVD Chapter creation (finally)
- Much better Titlepicture and ChangeCD picture color conversion when using I-Author.
- Added a CD Button. It's a newbie feature, just press it and dvd2svcd will locate the proper ifo file and load it.
- Fixed the bug where add vobfiles wasn't transferred to dvd2avi
Results 1 to 1 of 1
New PC Build(s)
By thedeificone in forum ComputerReplies: 6Last Post: 25th May 2010, 16:57 -
New PC build - please advise
By Poppa_Meth in forum ComputerReplies: 44Last Post: 24th May 2010, 12:32 -
New PC Build
By faramith in forum ComputerReplies: 37Last Post: 19th Oct 2009, 15:26 -
Watch movies online with other online also at the same time?
By Ghtpua in forum Software PlayingReplies: 5Last Post: 11th Feb 2008, 13:02
