Hello all,
I have been using an ADVC-100 for a while now but have recently been bugged by a recurrent problem.
I am capturing from a Scientific Atlanta Explorer 8000 digital cable DVR, s-video out to my ADVC-100 firewaire to our laptop and sinputing into WinDV.
I have noticed the problem periodically in the past but didi some captures this weekend and they all have it in places.
It is not always present but is expecially noticable when there is a bright contrasting color on a mainly dark or black screen.
There apear to be vertical lines about 2 or 3 lines wide evenl spaced about every 10-12 lines. The lines are verical and run evenly across the width of the screen. As is said, they are not always visible but are distinct when there is a bright color on a dark screen, especially noticable when panning.
Has anyone else had this problem and if so are you aware of a cause or solution?
Thanks,
Mike
Results 1 to 1 of 1
Bizarre vertical lines
By Asterra in forum Capturing and VCRReplies: 55Last Post: 17th Apr 2011, 21:46 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 01:23 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 13:21 -
Vertical Lines Appearing On Capture
By XBucklawX in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2007, 11:11 -
vertical lines in 2.5
By thekingbeyond in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 23rd Jun 2007, 14:53
