I have a DVD where the audio gets lost in the mix and the primary sounds are actually in the rear channel and instead of in front. This is not a problem when played through the surround sound amp (though it is annoying) but sounds terrible when I play the disk through the stereo tv in another room.
Can I remix the sound so that it is just stereo (it's an interview segment so I don't really care about the surround)? What tools are best to use?
I have DVD Shrink, Vegas 4, DVD LAb and Goldwave 4something. Can any of these be used to fix the audio the way I want?
Thanks.
dES
"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
vegas 4 can do a great job at remixng the channels
Should I import the video/audio in as 5.1 or as 2 channel stereo?
Then, would I tweak it by hand, or is Vegas kind enough to re-work it for me?
As an aside...WinDVD does a great job of playing it properly on my two speaker PC set up. This is why I am wondering if Vegas might acheive something similar on it's own.
Thanks."You can observe a lot by watching." - Yogi Bera
import all the channels (6) and pan each mono channel left or right or center (lfe and center) -- sometimes it sounds better to not use the surround channels at all
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
stereo downmix: surround vs surround 2
By codemaster in forum AudioReplies: 7Last Post: 29th Aug 2012, 12:06 -
Convert MKV to WMV w/5.1 channel surround?
By Spdngblt56 in forum Newbie / General discussionsReplies: 14Last Post: 21st May 2010, 02:11 -
"stereo" file (two channel signal) - Surround or Stereo?
By zee944 in forum AudioReplies: 0Last Post: 4th Sep 2009, 06:53 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 10:33
