Ok, here's my story, i have an NEC-2500A that's said to be an 8x dvd burner, and it came with a few 4x discs, and those burned just fine at 4x, but i recently bought some dvd+r's that are rated at 8x, the manufacturer is Unifino, and when i try to burn to them it only lets me burn at 2.4 or 2.5x, does anyone know a reason, or way around this?
Your writer is capable of burning 4x media at 8x, but only with certain media and clearly Unifino is not one of them.
You could try update your firmware either orginal or hacked.
You can get the hacked version here:
http://www.herrie.org/ -
I have the same burner and faced the same problem with Ritek 4X +R discs. Did what kyemeng suggested and flashed my firmware from v1.06, which came with the drive, to herrie's hacked firmware. I can now burn the same Ritek 4X discs at 8X with no read error.
However, I have never heard of Unifino. Don't know if the hacked firmware supports it.....
NEC TV to Pioneer DVD not working well
By Prasanna in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2008, 05:19 -
Imation not working in Nec 2500a
By anubis13 in forum MediaReplies: 3Last Post: 8th Oct 2007, 13:14 -
MAJOR probs w/ my NEC 2500A
By candlelight in forum DVD & Blu-ray WritersReplies: 25Last Post: 5th Sep 2007, 15:19 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 22:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13
