A friend of mine just upgraded his camcorder to a mini dv, he gave his old one. Now i've been using this camera for some time, my only problem is camera shake. Is there any filters for virtualdub or a standalone app (freeware would be nice) that will fix or soften camera shake. -garman
				Results 1 to 10 of 10
	http://biphome.spray.se/gunnart/video/
 deshaker filter for virtualdub
 free"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
	Thanks for your reply, I'll give this filter a try. -garman
	The deshaker filter is a bit trick to setup, but delivers good results. Be sure to read the instructions carefully.
	- SteadyMove for Adobe Premiere 6/PRO
 - Dynapel SteadyHandWant my help? Ask here! (not via PM!)
	Thanks for the tidbit of info. I'll give it a whirl very soon. Now that you mentioned the compexity of the filter, what about the processing times. I have a PIII 800Mhz with 512 of ram. Will this be sufficient or do I need to upgrade. -garman
	they all work about the same - more or less .. lot of factors and setup ..
 there are some high end tracking apps that do do a better a job (like in fusion)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
	Tri-pod. You will look like a geek when you are shooting and they can be a hassel but there is nothing better. IS IT SUPPOSED TO SMOKE LIKE THAT?
	I hate them all.Originally Posted by mikesbytes
 I've never gotten good results, not unless I pick apart the video scene by scene. Pain in the butt ... but it works.
 BJ_M probably is used to scene by scene, but not me.
 You've got to tweak to death too, otherwise it does some really flukey stuff.Want my help? Ask here! (not via PM!)
  How to Remove Camera Shake from iPhone 4S Videos (Batch Deshaker Script)By preshing in forum EditingReplies: 1Last Post: 17th Apr 2012, 23:35
  How to get DePan for AviSynth to fix Screen Shake?By VideoFanatic in forum RestorationReplies: 45Last Post: 30th Nov 2011, 08:49
  Reducing Camera shake in post productionBy Dannyboy125 in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2011, 08:42
  Shake 4.1 on the new MacBook Pro? Does it work well?By accumulator in forum MacReplies: 1Last Post: 17th Mar 2009, 13:22
  Remove some shake from videoBy helper in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2008, 15:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
