I see the sponsor on the main page now has these advertised. Couple questions:
1. How fast are they? I mean how fast is a single cd to cd copy? I assume they copy to cdrw as well?
2. There is no hard drive I take it? so nothing is ripped to a physical disc?
i dont see the ad - so send me a link and i will check it out for you ..
Thanks BJM. Its right on the main page. Seems like some sort of java ad so maybe thats why you arent seeing it.
anyway, the link is http://www.runtechmedia.net/
I wonder if you could set it up as a ripping station and rip 4 or 5 cds at once? I guess if its doesnt have a HDD thats not possible.
thx.
Tygrus -
no - it will not rip as you are thinking ...
it does have a hard drive and is stand alone - or used with an external firewire connection in addition (optional) '
the price is good and looks ok ...
other companies sell something like them ... also .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
No they work the other way round you put one disk to be copied in and then it will do how ever many copies you have burners for. So the 1-3 will do 3 copies at a time the 1-5 will do 5 off the same disk at the same time.Originally Posted by tygrus2000Not bothered by small problems...
Spend a night alone with a mosquito
Anyone familiar with zip spin stand-alone duplicators?
By AngieM in forum DVD & Blu-ray RecordersReplies: 9Last Post: 13th Mar 2010, 11:49 -
Change bitsetting on DVD Duplicators?
By wetcamelfood in forum Newbie / General discussionsReplies: 7Last Post: 14th Sep 2008, 14:58 -
Blu-ray Duplicators
By Yangster in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Aug 2008, 04:57 -
Disc duplicators
By kdlklm in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Oct 2007, 20:34 -
DVD duplicators
By Haopengyou in forum Authoring (DVD)Replies: 2Last Post: 29th May 2007, 00:17
