Lately when writing with my pioneer 107D, using Nero 6, I see the write buffer level fluttering randomly between 10%-98% and never stays put for more than a second. This is happening as of late with firmware 113. I recently installed firmware 116 and reinstalled Nero 6 but the same scenario is occurring. Anyone have any suggestions as to what could be the cause of this problem and a possible fix?
i manage to fix the problem. The hard drives should be DMA. I checked the specs and one of them had PIO.....dont know why its under PIO when (DMA if avaliable) is selected. I flashed my mobo bios and selected (use PIO) in device manager, exit then reopen and selected (DMA if availble) that detected my UDMA HD. Looks like somehow it click'd PIO. Every thing works fine now. thanks for the help guys :P
XP can sometimes change the DMA status of a DVD drive to PIO when the system has a difficult time reading a file. If you are having problems with burning speed or buffer levels, you should check it.
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 4Last Post: 4th Nov 2012, 08:57 -
CPU Temp Erratic and High in BIOS?
By bevills1 in forum ComputerReplies: 3Last Post: 7th Jul 2011, 12:09 -
Autoguessing of AVC level
By tom.tlr in forum Video ConversionReplies: 1Last Post: 14th Dec 2010, 14:25 -
convert .mkv from level @5.1 to level @4.1
By florinus in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2010, 16:33 -
Problem with WMV replay, erratic fast seek, what's the cause?
By J-E-T-S in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2008, 12:51
