which is better?
Results 1 to 17 of 17
Unless you got both its a hard choice.
Have a 108 and am happy with it.Not bothered by small problems...
Spend a night alone with a mosquito -
How does it do with CD-RW media? I have a 107D and it's SLOW....Originally Posted by iooi
Well specs say 30X I think.Originally Posted by JohnnyCNote
Only burned one cd as a test and that was at 20X worked ok for me.
Personally prefer to use a cd burner for cd's. Why no reason other than i have a cd burner in my system and it seems a wate not to use it...Not bothered by small problems...
I voted for the 3500 since I own one. I was debating whether or not to get the retail version of the Pioneer drive (A08) or the 3500. However, after reading the review on the 108 on Anandtech and seeing how the 108 uses an NEC chipset...I'm even more confused! Well, either way you can't go wrong.
I have the 3500. It is a very quiet drive, is not media picky, and so far burns all my media at the correct speeds all the way up to 8X.
you're right, I own a nec 1100...still works....just a matter of prefferences. I preffer nec for booksetting option...Originally Posted by bluntman72
they are the best burners out there. -
If you need the booksetting option, then there is no choice at all. A booksetting option just became available for the Nec 3500, and probably never will be available for the Pioneer 108.
NEC 3500A
FYI, there is a new (hacked) firmware that allows single layer bitsetting.
Check Herrie's site or the Dangerous Brothers. -
What media have you used that let you burn at 8x?Originally Posted by Bob W
Prodisc DVD+R 4.7GB, 8X, White Inkjet Printable, $0.45 eaOriginally Posted by bluntman72
Doubt that. Watch rpc1.orgOriginally Posted by henry_nettlesWant my help? Ask here! (not via PM!)
Optodisc 8X DVD+ROriginally Posted by bluntman72
Taiyo Yuden 8X DVD+R
Ritek Ridata 8X DVD+R
TDK 8X DVD+R -
Doubt what?Originally Posted by lordsmurf
Pioneer will never make a bitsetting firmware for SL DVD+R as they have no interest in making DVD+R more compatible. The Pioneer patchers at RPC1.org are also too biased against DVD+R to even have look at it although I doubt they would be able to add it even if they wanted as it's way more complex than removing limitations like region protection.
The bitsetting firmware (both SL and DL DVD+R) for the ND-3500A is available here: http://tdb.rpc1.org/#ND3500A
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
