I have enclosed the burning error from the saved log file when I tried to burn 2 files onto a DVD+R disc after converting the avi file to mpg files. I used Nero Vision Express and my hp media center PC burner. The burn failure log is very long but I enclosed the end of the log, hoping that the error is somewhere on this part of the text and someone could tell me where the error is.
Thanks all you computer gurus!
***END: _PGCI - Verify
***BEGIN: _PGCI - Verify
...size of VMGI = 16,384 Byte...
***END: _DVDBase - Create VMG
***BEGIN: _DVDVideo - Create OtherFiles
***END: _DVDVideo - Create OtherFiles
***BEGIN: dvd_eng_nero_conversion_manager - unload
***END: dvd_eng_nero_conversion_manager - unload
***BEGIN: _DVDVideo - Fill FileSystemDescContainer
...file allocation rules according to DVD Video Format specifications...
...file: 'VIDEO_TS\VIDEO_TS.IFO'...
...file: 'VIDEO_TS\VIDEO_TS.VOB'...
...file: 'VIDEO_TS\VIDEO_TS.BUP'...
...file: 'VIDEO_TS\VTS_01_0.IFO'...
...file: 'VIDEO_TS\VTS_01_1.VOB'...
...file: 'VIDEO_TS\VTS_01_2.VOB'...
...file: 'VIDEO_TS\VTS_01_0.BUP'...
...file: 'VIDEO_TS\VTS_02_0.IFO'...
...file: 'VIDEO_TS\VTS_02_1.VOB'...
...file: 'VIDEO_TS\VTS_02_2.VOB'...
...file: 'VIDEO_TS\VTS_02_0.BUP'...
***END: _DVDVideo - Fill FileSystemDescContainer
***END: DVDVideoSessionImpl - GetDiscContent
***BEGIN: DVDSessionBase - RegisterCallback
...Session callback unregistered...
***END: DVDSessionBase - RegisterCallback
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 6/17/2003 3:25:04 PM
Nero API version: 6.0.0.9
Using interface version: 6.0.0.8
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\NeroVision
=== Scsi-Device-Map ===
DiskPeripheral : ST3120025A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HP DVD Writer 300c atapi Port 1 ID 0 DMA: On
CdRomPeripheral : JLMS XJ-HD166S atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 511MB (523628kB)
Free physical memory: 157MB (161712kB)
Memory in use : 69 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.8.2004
NeroAPI
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.02.44a, size=17232 bytes, created 11/27/2002 12:02:00 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Maybe the error is not listed in the above excerpt. Does anyone need further info or more of the error log?
Error at the end when Ripping X-Men First Class
By slickster in forum Blu-ray RippingReplies: 3Last Post: 27th Oct 2011, 07:57 -
Verbatim DVDs with very high PI error/failure rates at the end of discs
By inoueto in forum MediaReplies: 10Last Post: 6th Mar 2009, 17:12 -
DivX v/s Xvid trial and error now puzzled, read toward end
By adiktlost in forum Newbie / General discussionsReplies: 7Last Post: 12th Jan 2009, 20:37 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
Error: Could not perform end of Disc-at-once - Please Help
By patrickj0781 in forum ComputerReplies: 7Last Post: 20th Jun 2007, 19:28
