Hello,
I have 2 problems:
1) I have movies DivX that work fine with subtitle (sub & srt files) from CD on that player. If I move them on DVD (exactly the same files), the player is not able to use the subtitles... When I try to choose the subtitle file, I select it but when I push the Subtitle on remote, the hand appears (void opperation). Also the subtitle icons on the file are not present, but they are marked with "?". Only changing the media (from CD to DVD) does this???
2) I have many small (5 minutes or less) avi files on the same DVD. I have to choose for each file the subtitle before playing the avi file...?!? It doesn't try to search the subtitle with the same name on file as avi... It's weird...
I hope that these problems will pe solved in a future version of firmware...
Does someone has a solution until then?
I had similar problem with my Hiteker He940, but i got rid of it by using better dvd+r media (ricoh, Platinum)
Originally Posted by poku
I burnt a movie with .srt subtitles on a DVD-R with Nero in DVD-ISO mode and the subs worked just fine. My brother burnt the same exact movie with Easy CD Creator in UDF mode (he said he finalized it) and not only did a take forever to load up it couldn't read the subtitle file, there was a question mark icon beside it. MY DVD burner is an LG and I use Ritek media, my brother's burner is an Asus and he used Maxell.
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 10:43 -
Divx subtitle on DVD/Divx player Problem
By abo_shreek11 in forum SubtitleReplies: 4Last Post: 24th Mar 2008, 14:39 -
By abo_shreek11 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Mar 2008, 03:41 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 14:06 -
Philips DVP642 and DivX 6/Ultra
By cheerful in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Aug 2007, 11:43
