Just looking for different advise as to what works best to convert a cue/bin file (movie) to DVD format and burn. It has to be DVD format as that is all my built-in dvd player will play. I have tried VCDgear and SVCD2DVDMPEG. Both give acceptable results but wondering if there is anything better?
Thanks,
dont quite understand what you mean. cue/bin are extensions of an image file. if you want to extract these files, use daemon tools to copy the files to your hard drive, and then use any conversion software to convert from vcd, svcd to dvd.
cue/bin are not movie files, they're just a way to package things. cue/bins can be anything from audio to software. once you open the bin files, then you use whatever method is best for whatever comes out...mpg, avi, divx etc
member since 1843 -
Thanks, they are MPEG files (movies). Was just wondering if there was any 1 program over another that would exctract with better quality or do they just extract as good a quality movie as is in the bin file?[/quote]
Suck it up princess !!! -
Extraction is just that...taking whatever is in the bin out, no conversion. That's what VCDgear does.Originally Posted by metallica
SVCD2DVDmpeg will allow you to put an SVCD on a DVD, without conversion as well. It changes the headers in the file so that it appears to be a DVD compliant resolution, when in fact it is not.
So your method is sound, you just cannot improve upon what you are given as a source file."Art is making something out of nothing and selling it." - Frank Zappa
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
