I have just recently bought a new dvd burner which is supposedly capable of burning Dual Layer DVD's. I use to use DVDShrink, to shrink the dvd's to a normal size for a dvd-r and then use nero to burn them. I have looked on this site a bit and I can't seem to find any help on burning these type of dvds.
What Burning program or Ripping&Burning program in one can I use to do Dual Layer DVD's? Is there a setting in Nero that needs changing to allow Dual Layer to be burnt?
Also am I only able to use DVD+R for Dual layer, or can I use DVD-R as well?
Thanks in advance for any help you can give.
You don't need to shrink if you have blank DL disks. DL = DVD9, so a commercial movie DVD (usually DVD9) will fit straight onto a DL DVD. You can use the new version of Decrypter to rip and burn or Nero 6 to burn. I think there are only DL+ disks at the moment.
as winifreid says, there is no need to shrink and only +r is available for DL.
However, first ensure that your standalone dvd player is compatible with DL disks. what type of dvd burner do you have. if it is a lite-on, you can have the benefit of using bitsetting to change the booktype to dvd-rom.
but DL disks are still quite expensive, might to best to stick with single layer dvd+-r for the time being. -
The burner is a LG burner, but I don't know the model number. As for if my Standalone DVD Player plays DL, I know it plays it on dual layered hired or bought dvd's, but as for burnt DL ones I will have to try and see by burning one.
Thanks for your help. -
Forgive me if I'm asking the obvious, but you do know there's a difference between regular DVD+R media and DVD+RDL media right? Just because you have a DL burner doesn't mean you can burn 8.5GB to just any old disc, you need special media.Originally Posted by hawthorn
Example of DVD+R media
Example of DVD+RDL media
Just the way you worded your question makes me believe that you think all media can be burned DL with the writer you have.
-Evan-[/url] -
This link might help you:
https://www.videohelp.com/forum/viewtopic.php?t=225001"The avalanche has already started; it is too late for the pebbles to vote."
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
Question on Dual Layer burning....
By ranchhand in forum DVD RippingReplies: 12Last Post: 4th Dec 2010, 17:26 -
Burning dual layer question
By ny888 in forum DVD & Blu-ray WritersReplies: 2Last Post: 4th Dec 2008, 19:01 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 10:00 -
Question about Burning an Entire DVD9 Movie to a Dual Layer
By |-Goku-| in forum DVD RippingReplies: 9Last Post: 30th Dec 2007, 19:41
