Hi
I back up dvd's using Clonedvd and Anydvd - which seems to work perfectly well if all I want is 1 copy. It's when I try to copy the copy that I get into difficulty. Clovedvd won'y do it (comes up with an error message that I can't recall as I am at work at the moment) and when I try to use Nero it won't recognise that there is a dvd in the drawer.
If anyone can help me with this dilema I would be extremley grateful.
Pegasus![]()
Hello,
Use dvd decrypter or dvdshrink.
Try DVD Decrypter. Read in iso mode and write in iso mode.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Just the back up DVD has write error. Can't be back up any more with any programs.
Happen time to time. Even with DVD Decrypter or ANY programs.
If you want to back up data DVD, better with Nero Buring ROM. Click 'Verify data after burn'. Then you can be sure. -
Try ripping the copy to a folder ( setting in ISO read) then burn that ISO (using ISO write mode) If you use the original then you will have to shrink it again.
Copy your original with CloneDVD as per normal. When you want to make a copy of a copy, try the DVDDecrypter ISO Read guide here, then the DVDDecrypter ISO Read guide here.
If in doubt, Google it.
Clonedvd 2 question...
By ironmanDD in forum DVD RippingReplies: 1Last Post: 21st Jan 2011, 00:41 -
An alternative to CloneDVD for BDs
By Evergreen4 in forum Authoring (Blu-ray)Replies: 4Last Post: 7th Jan 2011, 10:02 -
Which is better DVDfab or AnyDVD/CloneDVD?
By Vrex in forum DVD RippingReplies: 17Last Post: 23rd Mar 2008, 21:46 -
Do i have to get clonedvd?
By blaqlion22 in forum DVD RippingReplies: 3Last Post: 30th Jan 2008, 11:28 -
CloneDVD or Shrink?? Which is Better?
By Jonathan in forum DVD RippingReplies: 15Last Post: 22nd Dec 2007, 21:52
